I have 2 PPP connections to my ISP. Each connections gateway is the same IP address 192.168.175.1.
I added two default routes as below, but only one uplinks is used, other one is not utilized.
I have L009UiGS-2HaxD with routeros 7.15.1
How can I use ECMP?
[admin@MikroTik] /ip/route> print detail
Flags: D - dynamic; X - disabled, I - inactive, A - active;
c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn; H - hw-offloaded;
You might have to resort to using two VRF’s and mangling traffic to split across the two VRF’s. It wouldn’t be ECMP, but it would accomplish the same purpose.
If you really want ECMP, two routers could do it, one in front with two VRF’s, each with a PPPoE link and a gigabit port, handing off those two ports (and two different IP subnets) to the second router. The second router would think it’s connected to two different ISP’s and would happily load balance.
