Good morning.
I have a question with ECMP: i would like to know if it’s possible or what alternatives there are to do load balancing in this tophology with OSPF or another IGP:
R1 --------> Sw1 --------> |
| | R2
|__________> |
R1 = CCR2004 (router with OSPF)
Sw1 = CRS317 (switch)
R2 = RB4011 (router with OSPF)
R1 → Sw1 is a 10Gbps FO link
Sw1 ->R1 they are 2 wireless links
R1 SIDE:
/routing ospf instance print
Flags: X - disabled, I - inactive
0 name="default-v2" version=2 vrf=main router-id=172.24.1.1 originate-default=never
/routing ospf interface-template
add area=backbone-v2 comment="R1->R2 1st link" cost=10 interfaces=bridge1 networks=172.23.0.12/30 priority=1 type=ptp
add area=backbone-v2 comment="R1->R2 2nd link" cost=10 interfaces=bridge1 networks=172.23.0.36/30 type=ptp
/routing ospf neighbor print
1 D instance=default-v2 area=backbone-v2 address=172.23.0.14 router-id=192.168.251.21 state="Full" state-changes=10 adjacency=1d11h9m17s timeout=32s
8 D instance=default-v2 area=backbone-v2 address=172.23.0.38 router-id=192.168.251.21 state="Full" state-changes=6 adjacency=5m29s timeout=31s
/routing route print where dst-address="192.168.251.0/27"
Flags: A - ACTIVE; o, y - COPY; +, B - BLACKHOLE
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
DST-ADDRESS GATEWAY AFI DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
Ao+ 192.168.251.0/27 172.23.0.14%bridge1 ip4 110 20 10 172.23.0.14%bridge1
Ao+ 192.168.251.0/27 172.23.0.38%bridge1 ip4 110 20 10 172.23.0.38%bridge1
/ip route print det where dst-address=192.168.251.0/27
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, y - copy; H - hw-offloaded; + - ecmp
DAo + dst-address=192.168.251.0/27 routing-table=main gateway=172.23.0.14%bridge1 immediate-gw=172.23.0.14%bridge1 distance=110 scope=20 target-scope=10 suppress-hw-offload=no
DAo + dst-address=192.168.251.0/27 routing-table=main gateway=172.23.0.38%bridge1 immediate-gw=172.23.0.38%bridge1 distance=110 scope=20 target-scope=10 suppress-hw-offload=no
But traffic is using only the first route via 172.23.0.14 and ignoring the second one.
Any help would be appeciated!
