Is it possible to edit the size of a DHCP pool? For example I want to change my DHCP pool from a /26 to a /25… Is there a command that I can use that will do this without having to recreate the entire DHCP server?
The goal is to avoid any downtime…
Assuming the following layout (DHCP on 10.0.0.0/24 on a range from .10-.154):
[admin@Mikrotik] > /ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 10.0.0.1/24 10.0.0.0 10.0.0.255 LAN
[admin@Mikrotik] > /ip dhcp-server print
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 DHCP-LAN LAN DHCP-Pool-LAN 3h
[admin@Mikrotik] > /ip dhcp-server network print
# ADDRESS GATEWAY DNS-SERVER WINS-SERVER DOMAIN
0 ;;; LAN
10.0.0.0/24 10.0.0.1 10.0.0.1
[admin@Mikrotik] >
[admin@Mikrotik] > /ip pool print
# NAME RANGES
0 DHCP-Pool-LAN 10.0.0.10-10.0.0.254
Here are the steps to edit to go to a /23:
So, first change the subnet on the interface:
set [find interface=LAN] address=10.0.0.1/23 broadcast=10.0.1.255
If you find that you don’t want to recalculate values, you can delete the IP address and add it back in in under a second and have the router do it for you:
remove [find interface=LAN]; add address=10.0.0.1/23 interface=LAN;
Then change the DHCP server network:
set [find address="10.0.0.0/24"] address=10.0.0.0/23
Then grow the pool:
set [find name=DHCP-Pool-LAN] ranges=10.0.0.10-10.0.1.254
Hope that helps.
