Hello, I am writing here Since the support of Mikrotik not consult me.
I need to find myself somehow compile and edit a package RouterOS (main package), so that after recording himself turned ipv6 and wireless-cm2.
Mikrotik support wrote me that I should make a script that activates it to me, but in my case simply out of the question. I need to necessarily change the structure of a package, main package.
How come it’s not possible? Who decides which package will be active and which do not ???
Why is basically prohibited IPV6, why? For udružujete 3 different packages wireless? Why all of a sudden instead of active wireless package wireless-fp, why not directly active wireless-cm2?
I do not understand the whole logic of this decision, it was always only one wireless packet.
In another series I do not understand why leading a double system packages. One has packages individually and the second system has a single package. Of course, what happened is that we have a piece of equipment that have the system and the second part of the second network system, what’s the logic?
You will therefore interfere with one system? Or how will it be? Therefore arise similar problems. If the first system where packages are individually upload must be wireless-cm2 and do not record wireless-fp and automatically activates the package, but if I have a second system with one package, so I’m still on the old package.
The three wifi packages were already described somewhere here together with the future of removing one of them as I remember. I suggest not to use combined package at all but use own selected individual packages you need only.
Yes, now I also saw that the group package is totally useless because it can not be edited in any way, just because I do not understand why all originated. For example, why is it not in the base package hotspot is active, what the vast majority of equipment used hotspot? I do not understand
