editing login.html (uppercase/lowercase)
any idea to uppercase or lowercase all submited login ?
i modify this at login.html
function doLogin() {
document.sendin.username.value = document.login.username.value> .toUpperCase()> ;
document.sendin.password.value = hexMD5(‘$(chap-id)’ + document.login.password.value + ‘$(chap-challenge)’);
document.sendin.submit();
return false;
i input lower username but it doesnt work , i still got lowercase username on radius.log
any clue ?[/quote]
Might be that your RADIUS server does a conversion to lowercase of the usernames he’s receiving? Wouldn’t be too uncommon…
Best regards,
Christian Meis
there`r lower_username at radius.conf but i set it to NO. i checked at radius.log it showed username that i had input without any conversion.. any way to convert all username to uppercase/lowercase before it send to radius ?
