Editing on mobile phone with Edge
Anyone else able to post replies to here on mobile? Android with Edge. When I hit the reply box, the edit box appears at the bottom but then is hidden instantly by the keyboard. I can see just the very top of the edit box.
Writing/editing post with Edge on Android works on my phones and tablet (this post is being made with it). However, selecting text on the page with long press no longer works. The phone vibrates but nothing happens.
Maybe you can try an alternative keyboard? I'm using Microsoft SwiftKey.
I'm using Chrome on Android on my phone (same engine).
Keyboard pops over the edit box frequently indeed.
What I do then is hide keyboard, make edit window a bit larger, then use keyboard again.
I have toyed with Switftkey in the past but somehow I keep going back to native Samsung Keyboard.
Thanks, I'll have a go with making the edit window bigger. Bit of a flaw. Use a few other Discourse forums - will try there as well. Swiftkey - now there's a blast from the past!
