Hello to all.
I have a problem with editing scripts in telnet session. After “system script edit 1 value-name=source” I get to the editor and there is a bug or somwthing about that. If i try to delete a long string of script from the end of it by backspace then the interface hangs on with a symbol < and there is nothing to do except rebooting a device (RB 450g, ROS v4.6). However RB works normally with all configuration done before that but it is impossible to get into conf. interface by telnet or ssh, RB checks login and password and shows “Mikrotik” ASCII-picture but nothing else happens and no command line appears. After reboot RB works correctly but it isn’t always possible to take such measures if you’re trying to configure it from a distant place. So there are questions. Is it a common bug or something like that and if it is then is it possible to remove it?
Pls answer somebody if you have the same problems or you don’t have them in the same situation.
