Hello Dudes,
My clients use p2p software like edonkey and warez. This consume my upload. How do I solve this problem?
use the P2P filtering which is in RouterOS.
http://www.mikrotik.com/docs/ros/2.9/ip/mangle.content#6.37.3.1
I have tried that, but they still pass through. They seems to use dynamic ports
It work with protocols not with ports
Note that warez, at least, cannot be rate limited as only the search traffic is detected. So the search traffic must be completely dropped in order to make the application useless.
The same for Ares which is using the same warez P2P protocol.
Thanks a lot. I am cruising now. Mikrotik is wonderful.
Ares and bShare (gnutella) is not possible to limit! Block only.
