http://www.mikrotik.com/testdocs/ros/3.0/pnp/proxy.php
^So i'm in the "/ip proxy" submenu, and I'm not seeing the cache-drive variable anywhere. I've tried diving into the "set" global variable and seeing if it's a local variable in there. This seems like the most logical place for it.
Next, I stumble upon this little gem:
^So I get all excited because I think I've finally got the right resource here. The problem now is that I don't have the "Stores" directory under root. I seriously think that either A) RouterOS changes A LOT between versions, or B) Their documentation assumes a lot of things about prerequisite experience.
Can someone please help?!
routerboard: yes
model: "532A"
serial-number: "114701D21BEE"
current-firmware: "2.18"
software-id: "XXXX-XXXX"
old-software-id: "XXXX-XX"
upgradable-to: v3.x
nlevel: 4
features:
Flags: X - disabled
NAME VERSION SCHEDULED
0 X routing-test 3.30
1 routeros-mipsle 3.30
2 system 3.30
3 X ipv6 3.30
4 wireless 3.30
5 ppp 3.30
6 hotspot 3.30
7 security 3.30
8 dhcp 3.30
9 routerboard 3.30
10 routing 3.30
11 advanced-tools 3.30
upgrade-firmware: "2.18"
Hope this helps!
