Egress Filter DNS / Use only DHCP DNS Settings
Greets: I searched but didn’t see a specific post on this one–but maybe I missed it. I would like to require all internal users to only use OpenDNS. Here’s the way I think it should work, but I wanted to get a sanity check before I try it in production.
  1. OpenDNS addresses set on the routerboard for DNS (208.67.222.222, 208.67.220.220)
  2. Gateway address (w.x.y.1) pushed out via DHCP as the only DNS server address (w.x.y.1).
  3. Allow tcp/udp 53 to w.x.y.1 on internal
  4. Block tcp/udp 53 on internal
Not sure if step three is necessary…it would be on the same network… Appreciate any comments–pretty new to RouterOS, so be gentle with me :slight_smile:
That’s the right way to do it. Just to clarify item 4 - you want to block outgoing requests to tcp/udp port 53 in the forward chain, in-interface=LAN
You can also add a nat rule to force dns requests to the router even if a client is sending the request to something else:
add action=redirect chain=dstnat comment="redirect dns to router" dst-port=53 in-interface=localbridge protocol=udp
Hope that helps
Nick
