Add EiOP (still disabled interface) to BRIDGE1.. you cant be able to connect to https://community.spiceworks.com/ many TCP errors, not closed TCP (WIRESHARK)
I agree with you*), however, this is a fellow user forum, so just complaining about things here won’t change anything. To get issues resolved, you have to file a ticket at Mikrotik’s ticketing system.
*) on the other hand, you’ve probably planned to use the EoIP for something anyway, and once enabled, it would have caused the same issue. So you need a very specific (and short-lived in real deployment) setup to get affected by the issue that the bridge takes into account also disabled interfaces when adjusting its MTU to the lowest one out of those available on all its member interfaces.
