I don’t know VLANs.
I read PCunite’s tutorial 20x, I’ve watched 19 videos, read 18 articles, reviewed 17 threads here, 16 threads elsewhere, and tried 15 times on my own, and given up 14 times already.
Please don’t tell me to study or work harder. If I could have, I would have.
I set up a wAPax I had sitting around, connected its ether2 to my LAN, and got it up and running.
My goal is to get past my major blockage towards understanding and being able to work with VLANs.
My idea here is to set up the wAP so that all wifi connections to the wifi slave interface under wifi2 (5ghz) named “wifiguest-VLAN10” will be on their own VLAN (10) and have no access to anything on the LAN (which is otherwise accessible on ether2). But, wifi connected stations will have connectivity to the Internet (which is the main router at 192.168.2.2).
Here is what I have so far. I know it’s a mess. What would very much help is the most basic configuration to make it work using VLANs. That is, too much and my confusion will cause my brain (CPU) to reject (drop) all.
# 2025-02-18 20:51:23 by RouterOS 7.17.2
# software id = 4R3U-1R3M
# model = wAPG-5HaxD2HaxD
# serial number = HH80xxxxxx
add admin-mac=F4:1E:57:69:AD:13 auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-69AD14 \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
.ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-69AD14 \
.ft-over-ds=yes
add comment=wifiguest-VLAN10 configuration.mode=ap .ssid=wifiguest-VLAN10 \
disabled=no mac-address=F6:1E:57:69:AD:14 master-interface=wifi2 name=\
wifiguest-VLAN10 security.authentication-types=wpa2-psk
/interface vlan
add interface=wifiguest-VLAN10 name=VLAN10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec proposal
add name=default-dhcp ranges=10.10.10.0/24
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge comment=wifiguest-VLAN10 frame-types=\
admit-only-untagged-and-priority-tagged interface=wifiguest-VLAN10 pvid=\
10
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=wifiguest-VLAN10 vlan-ids=10
/interface ovpn-server server
add mac-address=FE:01:B6:23:41:05 name=ovpn-server1
add address=192.168.2.88/24 comment=defconf interface=bridge network=\
192.168.2.0
add address=10.10.10.1/24 interface=wifiguest-VLAN10 network=10.10.10.0
/ip dhcp-client
# Interface not active
add address-pool=default-dhcp interface=VLAN10 name=defconf
/ip dhcp-server alert
add disabled=no interface=bridge
add address=10.10.10.0/24 comment=defconf dns-server=10.10.10.1 gateway=\
10.10.10.1
set allow-remote-requests=yes servers=9.9.9.9
/ip dns static
add address=10.10.10.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
connection-state=invalid
/ip ipsec policy
set 0 disabled=yes
/ip ipsec profile
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ipv6 firewall filter
"defconf: drop everything else not coming from LAN"
/system clock
set time-zone-name=America/New_York
/system identity
set name=WapAX
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time-a-g.nist.gov
add address=time-a-b.nist.gov
add address=time-a-wwv.nist.gov
/tool mac-server
/tool mac-server mac-winbox
