Email notification on HDD fail
I have a problem with x86 and USB drive. Sometimes the system works fine, but it does not record data on the HDD. At that moment you can log in without a password!
after
/system reboot
I lose connection to the device, the only option is to turn off the power for a while.
At that moment I can’t write anything on HDD (such as backup or export configuration) probably system works from RAM.
I was thinking about a script that export eg. /system identity name to a file
and send an e-mail if operation fail.
I tried to write a script, but I wasn’t able to catch this information from logs
Any solutions?
Do the logs show some kind of error? Or does an error even show up at all?
funny thing, I got this problem right now.
I’m unable to open New Terminal window :confused:
