email notification problem
I’ve got thedude 3.6 installed on a dual xeon pc ROS router.
I’ve got the ROS correctly configured to send email through an authenticated server which works fine.
The email notifications from thedude work fine if I send them to the same IP as the authenticated server set up in the ROS.
For the life of me though I CANNOT get the Cc field to do ANYTHING with Thedude’s email notifications.
It sends to the single address in the address field fine but it WILL NOT send to the Cc address.
I need it to send to two email addresses at the same time.
Is there anyway to do this with Thedude?
Is this a known bug?
For some reason I can’t find any info on this out on the web.
Not elegant but you can duplicate Notification to say Notification2 and enable it with a different first user…
Although it’s not working mailCC do not send, is there any solution?
please post all your configuration, maybe mail configuration is not correct?
