email smtp access
hello all
got a stupid question my mail server requires SMTP authentication . how do i send it to the server when i am tring to send a email from MT to my email acount.
ie x@xyz.com password is 12345
how do i send to passoword and user name for that account
Randy
If I remember correctly, this was discussed in the forum (do a search). You cannot authenticate against a SMTP server from MikroTik.
Either send directly to the server where the destination address resides on (then it should accept it even without SMTP auth) or do send via a SMTP server which accepts messages from your MikroTik (like permitting SMTP from its ip address without SMTP auth or the like)…
figured it wouldnt be easy.
i could send it to my phone?
thanks
Hmmm, beats me. Depends on you phone operator. Most allow sending of e-mail to a mobile phone, but if they require SMTP auth - I don’t know…
Perhaps just try it?
it helps to own the mail server . i just gave a email address auth. to send from out side my networks . works fine now
Randy
