Would we be able to put in emojis into the comments, dhcp name, interface name, etc. It would be fun. ![]()
No emojis. There is no UNICODE support at all (e.g. UTF-8 or UTF-16). RouterOS, essentially, uses single-byte code pages, specifically CP-1252.
See https://en.wikipedia.org/wiki/Windows-1252 for your options, mostly latin-based accents/etc. e.g. following add “€×××” as comment to ether1:
/interface/ethernet set [find default-name=ether1] comment="\80\D7\D7\D7"
And with this trick, the extended ASCII even then they only show up in winbox, as via CLI you’ll see just the hexstring code. Basically, only plain us-ascii only thing works everywhere.
Have you tried unicode ?
/interface/ethernet set [find default-name=ether1] comment="\01\F4\80"
/interface/ethernet set [find default-name=ether1] comment="\F0\9F\92\80"
Have tested my self and seeing thats not working ![]()
You can use emojis in SSID, this is fun to have wifi named just ![]()
/interface wifi set [find name="wlan1"] configuration.ssid="\F0\9F\A5\B0"
https://observablehq.com/@a2m0/utf2rsc#decodeStart
or
https://r-1.ch/mikrotik-unicode-ssid-generator.php
