EMP8603 wrong power setting
Dear All
l Have EMP8603 cards which use to show 25 dBm in winbox tx. But now in the 3.17 to 3.23 it show 19 is this card also having offsett for tx power.
Whick is the best high power card for outdppr hotspot with 15 db omni 2.4ghz.
Thanks in advance
according with it datasheet has in b/g 9 db of offset and in a band 7 db
i have the same problem, the emp8603 shows only 19db in 2.4ghz, B only.
In their datasheet is advertised as 800mW , and that is 29dBm
On every setting that i’ve tried, the max output power is 19dBm.
What could be the problem ?
put in default setting the TX power output
for example if it show u 19 db means = 19+9 = 28 dbm ~ 800mw
