Hi Mikrotik folks,
I have purchased a new router CCR2116-12G-4s+ (arm64) ROS version 7.13.4. I was unsuccessful in applying e-BGP settings in ROS v7 where the e-BGP session did not display anything. Here’s the information from my ISP:
GLOBAL >> LAN 3 >> BW 140Mbps
DOMESTIC >> LAN 4 >> BW100Mbps
BW Total : 240 Mbps
# IP GLOBAL #
IP ADD : 179.20.18.60
SM : 255.255.255.252
GW : 179.20.18.59/30
# IP DOMESTIC #
IP ADD : 175.30.18.82
GW : 175.30.18.81/30
IP GATEWAY PUBLIK 1 : 104.99.182.128/29
IP GATEWAY PUBLIK 2 : 180.250.18.92/29
as number : 89898
remote as : 7713
The following are the settings that I have applied to ROS 7 :
set [ find default-name=ether1 ] name=ether1-global
set [ find default-name=ether2 ] name=ether2-domestic
set [ find default-name=ether3 ] name=ether3-public-104
set [ find default-name=ether4 ] name=ether4-public-180
set [ find default-name=ether10 ] name=ether10-local
add name=dhcp_pool0 ranges=192.168.10.2-192.168.10.254
add address=179.20.18.60/30 interface=ether1-global network=179.20.18.58
add address=175.30.18.82/30 interface=ether2-domestic network=175.30.18.80
add address=104.99.182.129/29 interface=ether3-public-104 network=\
104.99.182.128
add address=180.250.18.92/29 interface=ether4-public-180 network=180.250.18.91
add address=192.168.10.1/24 interface=ether10-local network=192.168.10.0
add address-pool=dhcp_pool0 interface=ether10-local name=dhcp1
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip firewall address-list
add address=104.99.182.128/29 list=my-network
add address=180.250.18.91/29 list=my-network
add action=src-nat chain=srcnat comment="global to 104" src-address=\
179.20.18.60 to-addresses=104.99.182.129
add action=src-nat chain=srcnat comment="domestic to 104" src-address=\
175.30.18.82 to-addresses=104.99.182.129
add action=src-nat chain=srcnat comment="global to 180" src-address=\
179.20.18.60 to-addresses=180.250.18.92
add action=src-nat chain=srcnat comment="domestic to 180" src-address=\
175.30.18.82 to-addresses=180.250.18.92
add action=src-nat chain=srcnat comment="ether 10 to 104" src-address=\
192.168.10.0/24 to-addresses=104.99.182.129
/routing bgp template
set default as=89898 disabled=no output.network=my-network routing-table=main
add as=89898 disabled=no name=My_BGP routing-table=main
/routing bgp connection
add as=89898 disabled=no local.role=ebgp name=domestic \
output.network=my-network remote.address=175.30.18.81/30 routing-table=main \
templates=My_BGP
add as=89898 disabled=no local.role=ebgp name=global \
output.network=my-network remote.address=179.20.18.59/30 routing-table=main \
templates=My_BGP
From the settings above, nothing appears in the session.
Please help. Is there a setting I’m missing?
What script should I add to the BGP Filter?
