Just installed my first rb433 with ros3.10 and firmware .15
Winbox:
In the access list of all my routers I set a name for each router allowed to authenticate by the AP, which then in return pops up in the ´comment´column in the wireless tables when such routers is authenticated.
Now in the rb433 it doesn’t! Is this a bug in rb433?
In all other (100+) routers (rb133c, 112, 532,532A, 333, etc) it works fine, but not in rb433?
Also, in all routers, the comment given to a router in the ´connect to´ list never showed up in the wirelesstables ´comment´ column. It would be nice if this could be corrected too…
Can you post a screenshot about that ?I have tried with column and it seems to work for me.
Well, the particular problem re. the ´access list´ is solved. I had a ´ghost´ mac auth. to the AP (was on def. auth) from a remote CPE which happened to have an almost equal mac. so I took it as the one I was looking for.
Later corrected settings and since then the proper mac comes up in the reg. table with its ´comment field´ mark on.
Still have the missing comment fields of routers that are in the ´connect to´ list. But that is a miss in all ros versions, even the old 2.9 family. May be it is mend to be that way?
rgds,
