I have some dude agents in my network. When dude dude serwer gets information from routerboard using agent routeros tab is empty. But it can data from routerboard via snmp.
actually read the post and you will see that your problem is exactly the opposite. original poster said that SNMP works fine, but RouterOS doesn’t work.
I assume you correctly have entered the “username/pass” of the RouterOS user in the Device settings, and have marked the “RouterOS” checkbox
Yes user name and passwords are OK, if I enable SNMP on mikrotik, then dude reads SNMP information but it doesn’t read routeros. Dude reads information from other mikrotiks which it can access directly.
