If you do have the time i would appreciate some advise on how to enable the 5 GHZ band on a rb951g-2hnd with MikroTik RouterOS 6.46.4
I’ve simply reset the router to factory default en used the quickset to enable a “home AP” wifi config.
This works perfectly fine, is very flat and very simple
However when i check with my android phone i don’t see it broadcasting on the 5GHZ band, is there a simple command for the console or menu the alter in the webconfig in the same simple manner as the quickset to enable the 5ghz band??
When i go to the webfig i am simply overwelmed by config options, and when playing arround with them i don’t get it working.
I’ve got router OS 6.46.4, put in a quickset “home AP” to enable the wifi and would like to set the guest-wifi into a separate vlan.
Is there a commandline sample config which i could put in to get the vlan that is allso connected to port 2 of my rb951g-2hnd.
About your VLAN on Mikrotik. If the only intention is to have a wireless SSID (e.g. for guests) over VLAN, then just add it to the wireless setting of that (extra virtual) WLAN interface.
use “Advanced mode” to see ALL fields.
Fill in: VLAN Mode: “use tags”
Fill in: VLAN ID: your VLAN, must not be 0 or 1
That is of course the simple setup. You can have multiple VLAN’s this way (one per SSID)
The VLAN traffic will flow with all the rest of the (untagged) packets. No VLAN’s to be defined on the AP.
If you want to involve the ethernet ports as VLAN edge ports, or if you want to add IP services (like DHCP) , then as in the “Using RouterOS to VLAN your network” tutorial, you do everything on the bridge.
Doing it on the WLAN interfaces and on the Switch is also possible but complicates things, and Switch and Bridge should never be configured both in the same device.
