Enable a Mangle rule
Hello
This works from a temainal
/ip firewall mangle enable 7
But when I put it in the script source in winbox it does not work when i run it.
Also, what is policy in winbox scripts do?
am i missing something simple?
you must use find, for example:
/ip firewall mangle enable [ /ip firewall mangle find comment=“blablabla” ]
here is link what policies do:
http://www.mikrotik.com/testdocs/ros/2.9/system/scripting.php?permalink=0.8561919882755251
Thanks, That worked
I must have misunderstoot how it works
I will read more
Thanks again very much!
:slight_smile:
