Enable access from different sublan
I have a network 192.168.1.1/24 with a router (router B) with ip 192.168.1.200 that create another network 192.168.32.1/24. Router 192.168.1.1 (router A) have a static route to send requests for 32.1/24 to 1.200 (router B) and all works well. Router B have firewall disabled and forward all requests
Inside the 192.168.32.1/24 i have an HEX that have ip 192.168.32.10 (router C)
I can login from the network 192.168.32.1/24 in the HEX but ihave timeout when trying from network 1.1/24.
what should i set?
Please provide diagram+descriptions and configurations exported.. The only thing we know that one HEX is somewhere in your lan.
I found the solution,
I connected the lan in the internet port and I set gateway and DNS as 192.168.32.1.
I made a firewall rule to allow incoming traffic to 127.0.0.1 from 192.168.1.1/16
maybe in the previous setup I hadn’t got the gateway/dns so I could connect only from the same subnet as the interface but not passing through the other router 192.168.32.1
