Enable AP Isolation
Please let me know how to Enable AP Isolation in Mikrotik Wireless , I`m using R52H and DBII F20-Pro in same router box.
hi fren,
please try to uncheck of default-forwarding or cli,
/in wir
pri
set [your_wlan_interface_name] defult-forwarding=no
this my roamming ap on main tower remote to mountain.
[@@@@@@@@sectoral] > /in wir
[@@@@@@@@sectoral] interface wireless> pr
 0  R name="wireless" mtu=1500 mac-address=@@@@@@@ arp=enabled
      disable-running-check=no interface-type=Atheros AR5413 radio-name=""
      mode=ap-bridge ssid="@@@@@@@" area="" frequency-mode=regulatory-domain
      country=@@@@@@@ antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default
      rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
      basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=@@@@@@@
      tx-power-mode=default noise-floor-threshold=default periodic-calibration=enabled
      periodic-calibration-interval=30 burst-time=disabled dfs-mode=none
      antenna-mode=ant-a wds-mode=static wds-default-bridge=none wds-default-cost=100
      wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=no default-forwarding=no default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=yes
      security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
      hw-retries=@@@@@@@ preamble-mode=@@@@@@@ compression=no allow-sharedkey=no
regards, :wink:
Hasbullah.com
