i have a few queues and i would like to create a shortcurt to my desktop PC (Win 10) so i could enable/disable a particular queue, without user interaction. Is there a way to do this please?
Write a program that calls the MikroTik API to perform the actions.
It will depend on your type of computer (operating system) and your skills if this is a practical solution. I use it all time, using Perl programs (scripts) on Linux.
not really a programmer. i am using win 10 and i would like to have something like a bat script for enable and one for disable of a particular queue.
