Enable ether 3 interface when I have a hotspot in ether 2
First of all say hello, and thank the help that this forum has given me.
I have a hotspot configured on the ether2 (LAN) running without problems. The ip range of the hotspot is 192.168.100.1/24.
On the other hand I have a computer used as a server with fixed ip 192.168.100.130 connected by cable to ether3 (SERV)
The idea is that the users of the hotspot can enter (if they wish) the web page located on this server
The problem is that I can not enable ether3 so that the computer connected by cable can access the internet. and when I succeed (enabled ip> Adress List in the same range of ip) the hotspot is without internet. Nor did I find it when I made a bridge between ether 2 and ether 3.
Can someone help me?
Attached Winbox configuration:
