Good Day..
Hello.. [ Need help ]
i have a failover here
my 1st isp is on Ether 1 - pinged to primary google dns
my 2nd isp is on Ether 2 - pinged to secondary google dns
then my Lan is on Ether 3
my 3rd isp is on Ether 4 ( disabled ) & ( 3rd route disabled ) enables only for backup.
i would like to put a script that if my 1st and 2nd isp is down on netwatch
therefore my Ether 4 and 3rd isp route = enables , then if the two of them (1st & 2nd isp) goes “up” then disables my Ether 4 & 3rd isp route
but then i dont know how what would i code and where should i script.
[need help] tia..
here please check my Config sir.
i have 2 stations
my 1st station has 2isp which i use as wan1 and wan2.
my 2nd station has only 1 my other isp which have big loads of traffic.
but then sometimes my 1st station wan1 and wan2 goes down so i use my 2nd station as for wan3 for emergency backup connection.
i am using pcc load balancing on my 1st station and adjusted for my third wan.
3\0 wan1
3\1 wan2
3\2 wan3
and i placed routing marks for each wan routes.
