Can i have 1 user in Usermanager and enable multiple sessions for this user.
So that for example 3 customers can connect simultaneously using the same username and password?
Thank you
Thank you
In user manager 4 beta, just select the number of simultaneous sessions from the drop down list.
In earlier versions, the default permits multiple sessions.
i have done as you said, but still when the second user tries to connect, a message comes up:
“No more session allowed for this user”
Have you specified same in the hotspot user profile/ppoe profile? i.e shared users.
Yes, this has solved the problem.
Thank you
