enable netwatch
i want simple script to enable netwatch if ping down with dilea 2 minute
Here is an example how to use netwatch
http://wiki.mikrotik.com/wiki/Manual:Tools/Netwatch#Basic_examples
thx but i need script to enable the netwach rule
it easy script but need print command to enable and i dont know how to use it in script
thx i had find it
/tool netwatch print brief
/tool netwatch enable 0
It’s not a good Idea to use console numbers in scripts
This one is correct script
/tool netwatch enable [find host="x.x.x.x"]
thx
