Enable Routing Instead of Routing Test before upgrade to 4.x
Greetings
After upgrading a x86 box running 3.30 using routing test to 4.1, I found the routing package disabled. Fortunaley, I was able to conect to the remote box and enable th erouting package. I will be upgrading another 3.28 box runnig routng test later today and will enable routing instead of routing test before the upgrade and share the results.
Cheers
Joe
upgrade from 3.30 to 4.0 wath smooth for me… did you have ‘routing’ package installed and disabled in v3?
