Enabling a Static Route Causes Everything Else to Not Work
We currently have 2 WAN interfaces on our router. One is setup with a static IP and the other get the IP from the ISP via DHCP. Whenever I try to enable a static route to add the gateway for the former interface everything doesn’t route correctly. No one can get to the 'net from the internal network.
[admin@MikroTik] > /ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, r - rip, o - ospf, b - bgp
 #    DST-ADDRESS        G GATEWAY         DISTANCE INTERFACE
 0 DS 0.0.0.0/0          r 65.189.240.1    1        WAN
 1 XS 0.0.0.0/0          u 66.93.20.1      1        (unknown)
 2 DC 192.168.1.0/24     r 0.0.0.0         0        OCEAN
 3 DC 176.16.0.0/16      r 0.0.0.0         0        STROUDER
 4 DC 65.189.240.0/21    r 0.0.0.0         0        WAN
 5 DC 10.59.1.0/24       r 0.0.0.0         0        WiFi
[admin@MikroTik] >
Note: It says interface unknown because the interface and IP address are currently disabled as well.
try to do the following:
set add-default-route=no in dhcp-client, then add default gateway – `/ip route add gateway=65.189.240.1,66.93.20.1’
should work
That allowed me to go out on our static interface but everything else still doesn’t work. Even when I put in preferred sources.
