enabling and disable bgp peer in putty
Hello, with what command disable i bgp peer in putty via ssh?
/routing bgp peer
print
set 0 disabled=yesChange “0” to the index for the peer that you want to disable.
I want a script thats see if bgp peer is down
If the bgp peer is down that netwatch can activate a peer2
How can a script see if the bgp peer is down?
