I have discovered an interesting wrinkle with how RouterOS handles CRL that I wanted to share in case someone else is dealing with a similar issue.
For a long time, I have noticed that I get errors in the log if I enable CRL relating to my DoH configuration:
DoH server connection error: SSL: ssl: crl not found for: "C=AT, O=ZeroSSL, CN=ZeroSSL ECC Domain Secure Site CA" (6)
I thought this was a bug for a long time, but Mikrotik support informed me it’s because the intermediate certificate for my DoH provider (NextDNS) is not installed in the router. Installing the intermediate certificate (the one referenced in the error above) fixed this particular issue.
But then I discovered that, after rebooting, my router would not do the 802.1x authentication to my ISP’s OLT (AT&T fiber). It got stuck on “connecting…”, usually. Sometimes it would get stuck on “authenticating…” or just say “rejected”. I finally figured out that it was because I had “use crl” turned on for certificates.
I don’t understand why it should matter. I have the full chain installed on the router (4 certs). None of them has a CRL specified. I don’t know why it would prevent the 802.1x auth from working to use CRLs. I would think it would just ignore the installed certificate chain(s) that don’t specify CRLs, but apparently it breaks things.
In any case, this is a quirk of RouterOS (maybe a bug?) that I wanted to get Google to index in case someone else runs into it.
