Enabling Fast Transition leads to connect-disconnect loop
I have a Bang & Olufsen Beosound Level (WiFi speaker) that I want to connect via WiFi to my hAP ax². As soon as I enable Fast Transition on my hAP, the Beosound gets stuck in an connect-disconnect loop. I don’t know if this is something that B&O has to fix or if it’s on MikroTik’s side, so I thought I’d share. Is there anything I can do (besides disabling Fast Transition)?
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1 vlan-id=1
add bridge=bridge1 disabled=no name=datapath2 vlan-id=2
add bridge=bridge1 disabled=no name=datapath3 vlan-id=3
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-schwarzwald wps=disable
add authentication-types=wpa3-psk disabled=no name=sec-eifel wps=disable
add authentication-types=wpa2-psk disabled=no name=sec-taunus wps=disable
/interface wifi configuration
add country=Germany datapath=datapath1 disabled=no name=cfg-schwarzwald security=sec-schwarzwald security.ft=yes ssid=Schwarzwald
add country=Germany datapath=datapath2 disabled=no name=cfg-eifel security=sec-eifel security.ft=yes ssid=Eifel
add country=Germany datapath=datapath1 datapath.client-isolation=yes disabled=no name=cfg-taunus security=sec-taunus security.ft=yes ssid=Taunus
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg-schwarzwald slave-configurations=cfg-eifel,cfg-taunus
I don't have any experience with B&O gear ... but quite many IoT devices have sub-par support in their WiFi stacks ... meaning that they don't like if AP supports features they don't know/expect.
Usually solution is to create a virtual AP with security settings which match client's capabilities. In your case a VAP with FT disabled.
You can make that VAP member of same IP subnet which would still allow seamless communication with controlling devices (e.g. your smart phone, using a more advanced AP).
