I’m trying to enable Nstreme for 2 of the above mentioned setup. I’m running them in WDS AP mode. As soon as I select enable Nstreme, I loose the connection…
Am I missing something?
thanx
Well, you’re missing logs and config info… ![]()
Try setting hw-retries=15 on both ends and try again. Oh, and I assume you’ve enabled nstreme on both ends.
