enabling p2p queue by passes queue limit
I have one queue setup and working limiting down loads to 2m and 256 up. I attempted to add in p2p limiting at 128kup and 512kdown. However when I tested the config I found I was getting 5m down which is the limit of the connection. I removed the p2p-all and the queue works fine again. I have tried all sorts of things with the same results, can anyone tell me what’s wrong?
Erik
What kind of queues?
It is just a simple queue on the customer radio (RB133). I have set the up and down load and played with the interface setting under advanced and that’s it. I will work in one direction only.
Erik
Might be better off using queue trees…
I get the same problem i dont know if this is a bug or what, but if you have a normal queue, and you enable p2p queue it seems to disable all queue’s on that IP and lets him induldge on all the bandwidth he/she wants!!! that p2p queue is a very good idea but it is handy if we can use it!
Same problem here. I hadn’t mentioned it yet as I’m still figuring out queue trees.
