Enabling wlan1 crashes router
I’m running an Senao NL2511 PC Card in a PCI adapter (ricoh rl5c475). The Senao firmware is 1.1.1/1.7.4. The card loads and works few about 10 seconds then the router freezes. I’m running a VIA CL-10000 mini-itx motherboard. The both of the onboard ethernet work as does the dual intel ethernet adapter. This is the demo software within the first 24 hours of use.
Any ideas? I’ve tired the command in the CLI and in Winbox
I have this problem running AR5212 in Acrosser M9923 hardware, when the power supplies are marginal. Enable the WLAN and click the interface is disabled. Whats more annoying, is that it completely looses configuration settings, SSID, frequencies when it happens.. To fix it I either reduce the power down to 10db, or replace the power supply. I suppose its probably the 12v power supplies at their limits.
Ken K.
