I am configuring Mikrotik bridge using WinBox v2.9.5. This bridge will be the client (station) to ISP which I work for. I intend to use WEP for security.
My concern is that the WEP Key is being displayed in plain text. Is there a way of making the key encrypted. Can command line assist me to have this solved.
If I understand you right you want to stop your customer from viewing the WEP key, right?
To read it, he would have to gain access to the MikroTik at first.
Apart from that WEP shouldn’t be considered “secure” anyhow - there are tools all over the place to crack WEP keys effortlessly nowadays (and for some time)…
Exactly.
You know what, the bridge belongs to the Client. He will be administering it. That implies that accessing the Mikrotik is already automatic.
Apart from that WEP shouldn’t be considered “secure” anyhow - there are tools all over the place to **** WEP keys effortlessly nowadays (and for some time)…
I agree. However it is better to use tools than being given the WEP directly
I have Cisco Aironet 350 Bridge at the base. And this uses WEP as security option. While I am considering to change to other security options, I am already having clients to help. At first Intended to create specific ssid and wep for this client. There was no problem withWEP and SSID creation, however I had problem with maping these. The SSID i created works with old WEP key but fails with the new one. That is to say added key is not effective.
Any tip?
The issue of changing security type is under way, this is just a temporary solution.
