Encryption in Wi-Fi Wave2
Hello, I have a question about Wi-Fi security with the Wave 2 package. I mean encryption, can anyone explain the difference between CCMP (256) and GCMP (256)? And what is the safest configuration while maintaining high compatibility with client devices? In the old configuration method, there was mainly a distinction between TKIP and AES, while the options in Wawe 2 are relatively new and little described.
The second issue is whether it is worth configuring the encryption methods at all, assuming that the authorization will be WPA2-PSK and WPA3-PSK?
Thank you in advance.
