Enctypted VPN (pptp) - how to do it ?
Without no problem I’ve set up ppptp server and windows xp as a client.
But I cannot force windows/mt to encrypt the connection. Maby I need some VPN client for Windows (open VPN? will this work ?)
Can you give me any hints ?
Thanks for advise,
Mikolaj
maybe PPP profile - Use Encryption - set Required?
My mistake! I had checked compresion = yes and Windows can not “talk” to MT :slight_smile:
Now it is working as it should :wink:
