Is the default port mapping of RouterOS’s IP Masquerading endpoint-dependent or endpoint-independent? IE when a particular host inside of the NAT sets up a new outbound connection to a new destination with the same source port of a previously opened connection, does it use the same source port on the NAT or is the mapping dependent on the 4-tuple (source ip, source port, dest ip, dest port)? Endpoint dependent mapping makes NAT traversal much more difficult and arguably might be more secure. Is there some way to make RouterOS’s Masquerading to endpoint-dependent?
Looking in Linux, it looks like there is a flag (–random) to netfilter which turns the default behavior from endpoint-independent into endpoint-dependent, but I am not sure how to set this in RouterOS. There seems to be a random flag to NAT, but it does something else.
As a bonus, is the answer any different for src-nat instead of masquerading?
Thanks in advance.
