Hi:
I’m testing this hw as a client bridge and UBNT Bullet2 will be the next. AP is running ROS 3.25 + Ubiquiti SR2 on it.
Straight setup, sending info to MT-Syslog etc, no problem at al.
Than the labels on links … 1650 have a V2 MIB (+RFC1213) and was easy to add the labels both at WLAN and LAN ports using 1650 SNMP as data source.
Suddenly I noticed a huge traffic on 1650 labels despite the client PC is simply with a online radio open (64Kbps).
A glance at AP wireless link label I noticed both values was pretty close to each other.
Bottom line: EOC 1650 is measuring the total AP traffic at ROS WLAN port. Configured as a transparent bridge, the WLAN and ETH interfaces readings are the same.
Is it an EOC1650 MIB bug or any client set up as transparent bridge will have the same behaviour?
Regards;
