Hi!
Maybe someone Will find this useful: http://luka.manojlovic.net/2016/07/17/mikrotik-netwatch-enhanced/[I](http://luka.manojlovic.net/2016/07/17/mikrotik-netwatch-watchdog-enhanced/I) have created a script that does some additonal pinging after netwatch UP/DOWN is triggered so you do not change things (change configuration / trigger actions) until you are “sure” that IP you are watching is UP/DOWN for good.
In this script example I am pinging some IP and if it down I change the SSID of Wireless interface and change the security profile on that interface - I am sure you will be able to change it for your needs.
Luka
