Question : how to let Access Point run on Bridge mode? (vlan ID :100)?
p/s : SSID 1 (TestBridgeV100) SSID 3(TestNat) , Wireless connect to ssid 3 can get ip (192.168.23.x) can ping internet (8.8.8.8 ) can ping to acs url (x.x.x.x).
Try to connect to SSID 1 which is bridge mode but can’t get any ip , tried with few phone , some phone sometime can go thru , sometime cant , most of the time fail.
MicrotikRouterBOARD 1100AH X2 AH (WINBOX Setup)
Router 0
Interface > ether1 > Name : from_modem> apply > ok
Interface > ether6 > Name : to_switch> apply > ok
Interface > VLAN >New interface > name : vlan10 > VLAN ID : 10 > Interface : to_switch>apply > ok (remark : tried use service tag but cant work)
Interface > VLAN > New interface > name : vlan100 > VLAN ID : 100 > Interface : to_switch>apply> ok (remark : tried use service tag but cant work)
IP > Add > Address : 172.17.221.238/24 > Interface : from_modem> apply > ok **remark (source from cable modem ip)
IP > Add > Address : 192.168.10.1/24 > Interface : to_switch> apply > ok
IP > IP Pool > Add > Name : dhcp_pool2 > Address : 192.168.10.20-192.168.10.254> apply > ok
IP > DHCP Server > Add > Name : dhcp1 > Interface : to_switch> Lease Time : 3d 00:00:00 > Address Pool > dhcp_pool2 > apply > ok
IP > DHCP Server > Options > Name : AP > Code : 43 > Value : ‘http://******/service/tr069servlet’ > apply > ok
IP > DHCP Server > Network > Add > Address : 192.168.10.0/24 > Gateway : 192.168.10.1 > DNS Servers : 8.8.8.8 > DHCP Option : AP > apply > ok
IP > Route > Add >Dst. Address : 0.0.0.0/0 > Gateway : 172.17.221.10 > apply > ok
IP > Firewall > NAT > Add >Src. Address : 192.168.10.0/24 >Action > Action : masquerade > apply > ok
IP > DNS > DNS Server : 8.8.8.8
Switch 0 RG-S2928G-24P
Int gi0/1
switchport mode trunk
switchport trunk native vlan 10
interface vlan 10 mgt AP
no shutdown
ip address 192.168.10.2 255.255.255.0
interface vlan 100 user ip
no shutdown
ip address 192.168.23.2 255.255.255.
Interface giga0/24
AP(auto config by acs url)
ip access-list standard 2
20 permit 192.168.23.0 0.0.0.255
ip dhcp snooping
sntp interval 60
sntp server cn.pool.ntp.org
sntp enable
web-auth acct-update-interval 1
web-auth sta-preemption enable
spectral
cwmp
acs url http://******/service/tr069servlet
cpe inform interval 90
service dhcp
ip dhcp pool macc_sta_pool
network 192.168.23.0 255.255.255.0
dns-server 1.9.1.9
default-router 192.168.23.1
ip name-server 8.8.8.8
enable service web-server http
enable service web-server https
webmaster level 0 username admin password *****
macc wis enable
log_mng set up HTTP
log_mng set uu http://*******/log/upload
log_mng set upd 300
no service password-encryption
clock timezone CST +8 0
dot11 wlan 1
ssid TestBridgeV100
dot11 wlan 3
ssid TestNat
link-check disable
nfpp
wids
wlocation
vlan 1
name ap#outsideNetwork
vlan 100
vlan 233
interface GigabitEthernet 0/1
encapsulation dot1Q 1
ip dhcp snooping trust
interface GigabitEthernet 0/1.1
encapsulation dot1Q 100
interface GigabitEthernet 0/1.100
interface Dot11radio 1/0
no ampdu-rts
rate-set 11b mandatory 1 2 5 11
rate-set 11g mandatory 1 2 5 11
rate-set 11g support 6 9 12 18 24 36 48 54
rate-set 11n mcs-support 15
country-code CN
radio-type 802.11b
channel 1
antenna receive 3
antenna transmit 3
chan-width 20
interface Dot11radio 1/0.1
wlan-id 1
interface Dot11radio 1/0.3
encapsulation dot1Q 233
wlan-id 3
interface Dot11radio 2/0
no ampdu-rts
rate-set 11a mandatory 6 12 24
rate-set 11a support 9 18 36 48 54
rate-set 11ac mcs-support 19
country-code CN
no short-preamble
radio-type 802.11a
channel 149
antenna receive 3
antenna transmit 3
11acsupport enable
chan-width 20
interface BVI 1
ip address dhcp
ip nat outside
interface BVI 233
ip address 192.168.23.1 255.255.255.0
ip nat inside
wlansec 1
wlansec 3
ip nat inside source list 2 interface BVI 1
no offline-detect
line console 0
login
password admin
line vty 0 4
privilege level 15
login
password admin
end
