Enquiry on Inverse Mask
Hello all,
I am relatively new to RouterOS. I used Vyatta in the past.
We are running BGP with 2 full routes upstream ISP.
In the past, we use policy/route map/inverse-mask to match the incoming filter.
Specifically, we use the following to match - if incoming prefix is ..192-255.* , then set the local preference higher.
     rule 10 {
         action permit
         description "For x.x.192.x - x.x.255.x"
         source {
             inverse-mask 255.255.63.255
             network 0.0.192.0
However, I cannot find the similar in the RouterOS. Do you have any idea?
Or in RouterOS, is there easy way to select around 100,000 routes in the Route/Filter ?
Thank you very much for your kind attention
Regards
George
There is generally used exclamation mark to invert the value. Check if it apply to your case.
