Entering an "Empty" APN string - RBM33G
Hello
I’m trying to connect my MikroTik RBM33G to LTE with a Vodafone SIM-card. Usually vodafone uses “web.vodafone.de” as APN string in germany.
But this card only works if you enter nothing as an APN string. I’ve tested this on multiple devices (Teltonika LTE router, smartphone, Windows PC with Quectel Modem).
Also the config of the MikroTik LTE Router was tested successfully with other SIM-cards.
If I set the APN of the used LTE Profile to an empty string and apply, the router connects to the internet. The problem is that if I restart my MikroTik router it changes the empty APN to “internet” which I believe is the default value for this setting. Then the router doesn’t connect anymore.
Any idea how I set the empty APN permanently in a MikroTik LTE routerboard?
Help is much appreciated!
