EOIP and Balance-rr Bonding
From the wiki I understand that if I set up a bond between Ether1 and Ether2 on two routers using balance-rr mode I can increase my throughput for each TCP connection but frames may arrive out of order and some things might not like the out of order frames since Ethernet was designed to receive them in order.
If I follow this this example and create two EOIP tunnels and than bond those two EOIP tunnels will the ethernet frames be put back in order since they are riding in the EOIP tunnel? I would like to say yes since the bond is now happening with IP data and not Ethernet but I’m not positive.
Thanks,
Brad
I am also highly interested in this solution.
I want to use 2x rocketm5 links on a rb1200 on each side and bond the eoip tunnels to create maximum throughput.
This will be for a 100mbps internet connection, but i would like like to have the tcp packet errors ect..
Anyone tested this before ?
Here’s your other thread: http://forum.mikrotik.com/t/100mbps-internet-connection-over-bonded-help-needed/49451/1
Please don’t double post. It wastes everyone’s time.
