Hi Gurus,
I am about to try linking 2 sites via the internet using EoIP.
Here is the setup I am thinking of using…
LAN - RouterOS - DSL == INTERNET == Leased Line - RouterOS - LAN
The problem I see at the moment is at the point where the leased line is will be some kind of router. At this moment I have no control of it. I see this as being a stumbling block.
Anyone any ideas how exactly EoIP works (ie does it tunnel through a specific port?) and what I will need to request the router owner to do/check before I drive hundreds of miles for it not to work.
Many thanks
James
