I have working setup with two MT with EoIP tunnel between them.
But problem is, that ARP doesn’t get thru that tunnel!
If i use VLAN for tunneling, it works fine. Even more, if i use VLAN for a second (to pass ARP) and switch to EoIP, then it still works for couple of minutes (till the end of ARP entry).
And if i add propper ARP entries manualy, it works.
So, the question is, am i doing something wrong (no, i don’t have any firewall rules) or can it be some hardware issue?
And second thing, what is the difference between using VLAN and EoIP?
Make sure that ARP has not been disabled on the EoIP/Ethernet interface and bridge interface.
EoIP create Ethernet tunnel over IP, it means Ethernet connection is established between two remote networks.
VLAN is simply a way of grouping a set of switch ports together so that they form a logical network, separate from any other such group.
Provide us with some details, how ARP does not work for you ?
Post the following menus here,
‘interface eoip export’,
‘interface bridge export’.
Make sure that you are using the latest RouterOS version.
/ interface bridge
add name=“brg_lan” mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m forward-delay=15s
garbage-collection-interval=5s hello-time=2s max-message-age=20s comment=“” disabled=no
add name=“brg_adsl” mtu=1500 arp=disabled stp=no priority=32768 ageing-time=5m forward-delay=15s
/ interface bridge port
set eth_adsl bridge=brg_adsl priority=128 path-cost=10
set eth_lan bridge=brg_lan priority=128 path-cost=10
set ap_dobrzykowice bridge=brg_lan priority=128 path-cost=10
set eoip_adsl bridge=brg_adsl priority=128 path-cost=10
set vlan1 bridge=brg_adsl priority=128 path-cost=10
The EoIP interfaces are intentionaly disabled, because i currently use vlan.
Don’t look at ARP settings, because i’ve arleady tried every posible set (enabled, disabled, proxy…)
Both MT are 2.9.6, is this wrong?
