eoip bridge Arp problem
i have a verry strange problem…
i configured a lot of eoip tunnels with bridging but this problem really bugs me.. so all you network wizz, pls give me a hand…
local lan---------router A -----eoip-------router B-------local lan
both routers do bridging… of the eoip interface and the local lan interface.
both eoip endpoint have a non-existing mac adress on them.
the eoip and the local lan and the underlying interfaces all have arp enabled.
router a has local lan set to proxy-arp, for the PPTP dailin users with the same ip’s as the local lan interface
so i see traffic flowing in the bridge on both i see traffic on the eoip interface on both… now the problem…
if ip ping from router A to a router B adress on the local lan i get no reply.
if i ping from a pc after router A to a router B adress no reply…
not even arp…
if i ping from router B to router A or a pc after router A instant reply…
i get arp entries in both routers and pc
if i then ping from router A to B it works
ping from pc to router B works
after about 5 min of no traffic from router B…my reply from the router and pc time-out.
if i look in the router A arp table the adress is still there.
in the pc it says mac 00:00:00:00:00:00 invallid
if i ping from router B to A or the pc i have no reply…
if i now delete the arp from router A and from the PC
i have ping reply again in both directions for 5 minutes…
so my conclusion is… arp reply and request comming from router B to A or pc work…
arp reply/requests from router A or pc to router B don’t
i have absolutly no idea what to do…
any idea’s
pls guys…
normis or who ever…
i need your help
any idea’s
Have you fixed the problem? I have same in my setup
